Intel® High Level Design
722 Discussions
HLS support in Lite 19.1
SParv4
HLS is not available in the Additional Software tab, though the landing page for HLS :
https://www.intel.in/content/www/in/en/software/programmable/quartus-prime/hls-compiler.html?erpm_id=9341628
says HLS is supported by the Quartus Prime Pro Edition, Quartus Prime Standard Edition, and Quartus Prime Lite Edition
Is HLS supported in Lite for Cyclone 10 family? Because Xylinx seems to give an HLS compiler for their entry level FPGAs
MEIYAN_L_Intel
I had tried to install the Quartus Prime Lite v19.1 and I could not found the HLS compiler included in the Quartus Prime software package.
I am still clarify the information internally.
The Cyclone 10 LP family device is supported in Quartus Prime Lite v19.1 as stated in the link below:
https://www.intel.com/content/www/us/en/programmable/downloads/download-center.html
MEIYAN_L_Intel
I had installed Quartus Prime Lite v19.1 (window version) and Quartus Prime Lite v18.1 (window version).
In Quartus Prime Lite v19.1, there is no HLS directory installed.
But in Quartus Prime Lite v18.1, there is a HLS directory installed.
Could you try to install Quartus Prime Lite v18.1 with Cyclone 10 LP device supported and shown in link below:
SParv4
Hi, I tried 19.4 Pro with Cyclone 10 GX. This is my user feedback.
  1. Like AHDL, Verilog or Schematic, I should be able to enter my design in Quartus GUI itself using C/C++. (Well Quarts GUI itself has become old and requires renovation, e.g can use Direct 3D for RTL viewer, Pin Planner etc. Even android game have better user responsiveness)
  2. It should produce RTL logic as the above mentioned design files produce.
  3. Right now HLS compiles very slowly, produces so many files and the output is cluttered, that coding in AHDL or Verilog is easier.
I think HLS is not yet an alternate for the traditional design entry methods, but might soon become one.
MEIYAN_L_Intel
Thanks you for your information and feedback. I will report this to the developer.
According to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/hls/ug-hls.pdf, Intel HLS compiler compiles the design to an x86-64 object or FPGA-targeted RTL code, and creates an executable testbench.
After compilation in HLS, you may saw the HDL file in component directory.
Also, you can use the command "eg:  i++ --quartus-compile --simulator none -march=CycloneV counter.cpp -o test-fpga -v" and the results and files will be put in .prj/quartus directory.
For you information, the HLS compiler Lite v19.1 can be download as standalone software from https://fpgasoftware.intel.com/19.1/?edition=lite
SParv4
Thanks for uploading the HLS compiler Lite v19.1. I will give it a try with Cyclone10LP
I will also try  i++ --quartus-compile.
For counter.cpp the quaruts_compile.sv file generated looks good.
But for ''interp_decim_filter'' example the .sv file does not seem complete and instead links to a plethora of other component files?
That is not a problem as long as I can get .bdf or .ini (AHDL) file which I can use in my project without going through the Platform Designer.
MEIYAN_L_Intel
For your information, if you would like to add the generated IP into Platform Designer, you can refer to chapter 8.2 as document below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/hls/ug-hls-std.pdf
May I know which .sv file seem not complete as you mentioned earlier?
SParv4
The following is the output from the command prompt:
E:\intelFPGA_pro\19.4\hls\examples\image_downsample>i++ --quartus-compile --simulator none -march=Cyclone10GX bmp_tools.cpp main.cpp resize.cpp -o test-fpga -v
Target FPGA part name:  10CX220YF780I5G
Target FPGA family name: Cyclone10GX
Target FPGA speed grade: -5
Analyzing bmp_tools.cpp for hardware generation
Analyzing main.cpp for hardware generation
Analyzing resize.cpp for hardware generation
Optimizing component(s) and generating Verilog files
aocl-opt.exe takes CPU load of 25% for 2 hrs
How long will it take to generate??
SParv4
I tried this simple adder
#include "HLS/hls.h"   #ifndef __INTELFPGA_COMPILER__ #include "ref/ac_int.h" #else #include "HLS/ac_int.h" #endif     component uint8 s_adder(uint8 a, uint8 b) { return (a + b); }
and got the attached RTL.
The compile time , the convenience and finally the RTL generated is not satisfactory for at least simple systems.
I will continue with IP catalog and AHDL.
MEIYAN_L_Intel
Thank you for your information. I had reported to developer for this RTL generated with simple adder system.
