Intel® High Level Design
722 Discussions
Intel FPGA Edition SIM ERROR vopt-14408
TxLy123
There comes an simulation error :
Error (suppressible): (vopt-14408) Intel FPGA Edition recommended capacity is 5000 non-OEM instances.
I want to know how to solve it and make my simulation running.
I remember we can suppress this error to make it work, however , when I use this one vsim -suppress 14408, there is no change.
when I use this command, the transcript shows:
# No design specified
If you can tell me the solution, I will really thanks!
ShengN_Intel
Regarding the "vsim -suppress 14408" command, this command only suppresses the display of the error message in the transcript. Additionally, you need to specify the top-level design module you want to simulate after the vsim command. For an example:
vsim -suppress 14408 -t 1ps -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L maxii_ver -L rtl_work -L work half_adder_tb
Sheng
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
Eric_Liu
Thanks you Sheng, I got the same issue, but could be soloved after using your "suppress" command! It works!
ShengN_Intel
Does your problem being resolved?
Let me know if any further update or concern.
Sheng
