Intel® High Level Design
723 Discussions
Intel HLS (19.3) - Bad implementation of memory.
Pan
The expected implementation should have 1 Write (2 shared stores) and 1 Read (1 load) port. But those are the implementations in different cases:
  1. REG2_DATA_WIDTH 40 - Wrong implementation. The memory ended with multiple writes and ARB. II=33.
  2. REG2_DATA_WIDTH 41 - Expected implementation. II=1.
  3. REG2_DATA_WIDTH 48 - Wrong implementation. Multiple stores. II=3
  4. REG2_DATA_WIDTH 49 - Same as item 1 (40).
  5. REG2_DATA_WIDTH 64 - Expected implementation. II=1.
There is a method to trick compiler. And that is to define only one write into memory. But this shouldn't be the way to do it. It also raises another problems in more complex components.
The question. Why does this happen and what to do to avoid it? Is it compiler fault I have to circumvent?
The Conclusion. I ended with two possible versions why does this happen:
  1. The compiler tries to implement optimized memory, therefore it forces multiple narrower stores rather than one wider store.
  2. The compiler doesn't properly distinguish excluded stores. (Less likely)
MEIYAN_L_Intel
I had tried to compile the code and the attached code is not able to compile.
I have added the following line to make it compile:
#include <HLS/ac_int.h>
#include <HLS/hls.h>
#define HLS_COMPONENT component
#define REG_ADDR WIDTH 64
This appears to be a regression from 19.1; when compiled using 19.1, the 40-bit and 41-bit both worked nicely. It appears that in the 40-bit case, the compiler decomposes the 40-bit store into power-of-2 stores, 8+8+8+16. A workaround is to set the type in memory to be a 64-bit ac_int.
HRZ
Valued Contributor III
If you post a simplified code example that can quickly be compiled to show the problem, it would be much easier to understand and try to solve the problem.
Pan
I have already uploaded component part only. But here you go with full main.cpp with testbench. The results should be:
15
30
201
101
(For some reason I cannot upload more than one file at once.)
MEIYAN_L_Intel
I am still looking into implementation of memory in HLS.
Pan
is there any progress?
Have a nice day
MEIYAN_L_Intel
Pan
Thanks for your time. I know the behaviour of 19.3 compilation, the fact that 19.1 compiles the right way is interesting. The workaround is obvious, but it will consume resources.
Maybe the question is more about whether this problem will be resolved in the new version of Intel HLS?
Again, thanks for your time and have a great day.
MEIYAN_L_Intel
I had reported this problem to the developer and they had noted this problem as well.
They plan to solved this problem in newer version of Intel HLS.
Thank you for your information.
