Intel® High Level Design
722 Discussions
Intel HLS compiler does not find includes
Paba
Hi everyone
I am new to HLS and doing my first steps with the Intel HLS compiler. I am using Intel Quartus 18.1 which comes with an integrated HLS compiler and also provides with samples for people like me doing the first steps with it.
To meet the pre-requisites for the HLS compiler I have installed Visual Studio 2017 Professional edition on my computer. Then followed the installation and initialization instructions from the Intel Website: https://www.intel.com/content/www/us/en/docs/programmable/683053/19-1/installing-the-standard-edition-on-microsoft.html
After running the init_hls.bat I thought I am ready to run one of the first examples. So I picked the 'counter' project provided in the <quartus install dir>\hls\examples\counter folder. But when running the build.bat file I always encounter the following error:
I did some research through the web to solve this issue. Some stated that a different command prompt should be used to overcome this issue. Some said that you need to specify the correct paths. But so far I was not able to solve this issue. Can someone give me a hint what I can do so that the HLS compiler is able to find the correct paths for the standard includes?
aikeu
Hi Paba,
I will close this thread as this is a duplicate issue from another on-going thread.
Aik Eu
