Intel® High Level Design
722 Discussions
Interfacing DDR3 with DSP Builder. Adressbus size?
TKlei
I'm using DSP Builder with External Memory Write block to store data in an DDR3 RAM. However the generated memory address size ist 27 bit and not 22 as expected with the memory size configuration. In the dsp builder model the size is correct (see attached Image).
In the generated design file the Memory address bus is defined as:
Memory_Write_address : out std_logic_vector(26 downto 0); -- ufix27
After looking into the source files I discovered this:
-- Memory_Write_gnd_x(CONSTANT,5) Memory_Write_gnd_x_q <= "00000"; -- Memory_Write_address_join_x(BITJOIN,2)@4 Memory_Write_address_join_x_q <= Memory_Write_address_reg_x_q & Memory_Write_gnd_x_q;
Why is the address joined with "00000"?
NurAida_A_Intel
Hi Sir,
Good day to you.
May I know if you configure any 27 bits in your design (maybe at high level) ? And do you observed any functional/simulation failure with this generated memory address size of 22 bits?
NAli1
TKlei
​Hi NAli1,
There is no 27 bit in this design. Please find attached the design.
Thomas
NurAida_A_Intel
​Hi Sir,
Please accept my apology for the delay in response.
Are you having Avalon MM interface 256 bits, if yes, then it is make sense to have “00000”.
My understand is that, if your Avalon MM interface is 64 bits, you will read out 64 bits per cycle, so the byte address is (64/8= 8 or 1000), so it has to padded/joined with 3 zero (bit 0-2 are not used). For your case, I believe, the Avalon MM interface is 256 bits, 256/8 = 32 (10 0000), so they will see it is padded with “00000”.  So, if you having Avalon MM interface 256 bits, then it make sense to have "00000".
Hope this helps.
NAli1
