Intel® High Level Design
722 Discussions
OneAPI: FPGA simulation fails when using USM
Ali8
I have been trying the different OneAPI tutorial examples for FPGAs. I can run all the examples with FPGA emulation. However, FPGA simulation only works for examples that do not use USM or buffers (simulation works fine when using host pipes!).
When I try to run FPGA simulation for the vector_add example with USM, I get the following error message:
Assertion failed: *fd != nullptr && "IPCSharedMemoryMaster() failed to open file!", file src/acl_msim_mem_manager.cpp, line 185
I am using OneAPI version 24.1, Intel Quartus Pro 23.4 and Questa starter edition 23.3.
I am using “Arria10” as a target when compiling for simulation.
aikeu
Hi Ali8,
I will get back to you when I have the information to your question.
Aik Eu
aikeu
Hi Ali8,
I am not able to find the similar errors as you have observed from my side. Probably the below link may help with the errors:
https://www.intel.com/content/www/us/en/docs/oneapi-fpga-add-on/developer-guide/2024-1/compile-a-kernel-for-simulation.html
Aik Eu
aikeu
Hi Ali8,
I will close the thread if no further question?
Aik Eu
aikeu
Hi Ali8,
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Aik Eu
