Hi, I am trying to pass pipeArray through template in a functor.
The pipeArray code in the following oneAPI sample directory was used:
oneAPI-samples/DirectProgramming/C++SYCL_FPGA/include/pipe_utils.hpp
The pipe array definition:
// pipe array
using testPipeArray = fpga_tools::PipeArray<class testPipeArrayId, Data_t, kDepth, kWidth>;
Functor code:
template <typename inPipe>
class tileReadData{
public:
Data_t *inMatPtr;
unsigned total_reads;
unsigned mem_base_addr;
void operator()() const{
Data_t * inMatLocated(inMatPtr);
[[intel::initiation_interval(1)]]
for (unsigned mem_idx = 0; mem_idx < total_reads; mem_idx++) {
fpga_tools::UnrolledLoop<kWidth>([&](auto jdx) {
inPipe::PipeAt<jdx>::write(inMatLocated[mem_base_addr + mem_idx * kWidth + jdx]);
Used in code:
// data read
auto tileReadData_event = q.single_task<tileReadDataId>(
tileReadData<testPipeArray>{inMat, total_reads, mem_base_addr});
This code makes the following error messages:
error: no member named 'write' in the global namespace; did you mean 'fwrite'?
50 | inPipe::pipeAt<jdx>::write(inMatLocated[mem_base_addr + mem_idx * kWidth + jdx]);
error: use of alias template 'PipeAt' requires template arguments
error: SYCL kernel cannot call an undefined function without SYCL_EXTERNAL attribute
These error message does not come up when using pipe instead of pipearray (also without the unrolled loop). Is there a way that I can pass pipeArray in functor through template?
Hi @JSYOO,
Thank you for posting in Intel community forum, hope all is well and apologies for the delayed in response.
Noted on the error message, may I know what oneAPI version that you are using to compile the mention example? Also what are the compilation command used?
Hope to hear from you soon.
Best Wishes
BB
Hi I attached the CMakeLists and the sample source code.
I run the code on linux and it is running on oneAPI 2024.0 version because this is the only version I download for this machine.
the commands were:
$ mkdir build
$ cd build
$ cmake ..
$ make fpga_emu
The CMakeLists is based on the CmakeList from this repo:
Hi @JSYOO,
Noted on the version involved and code repo referred as well as shared sample code.
Please do allow us some time to emulate the provided code and get back to you shortly.
Thank you for the patients
Best Wishes
BB
Hi @JSYOO,
Thank you for the wait, this is to let you know that your request are still being worked on.
Will get back to you sometime within this week.
Appreciate the patients.
Best Wishes
BB
Hi @JSYOO,
The compilation from our end seems to be working and we are able to generate the emulation files for the fpga template.
Based on the error message seen per my understanding you are trying to use the pipe for IO and are facing some issues, there are example design available in the path below:
Perhaps there seems to be some declaration gaps for the pipe, hence would suggest to refer to the sample as a references.
Hope that clarify
Best Wishes
BB
Hi @JSYOO,
Greetings, as we do not receive any further clarification/updates on the matter, hence would assume challenge are overcome. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. For new queries, please feel free to open a new thread and we will be right with you. Pleasure having you here.
Best Wishes
BB
Hi, I tried running the code in couple other environments, but I am still having the same error with the code.
I am trying to pass the pipe array to a function or a functor.
I do not want to define the pipe array globally as in the sample above.
I have checked some of the samples using pipes as my intention (such as: https://github.com/oneapi-src/oneAPI-samples/blob/master/DirectProgramming/C%2B%2BSYCL_FPGA/ReferenceDesigns/matmul/src/matmul.hpp )
The pipe defined in line 93 is the type of pipe I want to implement, but in pipe array instead of pipe.
Is there any samples that defines and passes pipe array instead of pipe to another function or a functor?
![](/skins/images/7400F44FEAF4312DA521E61720D9D5D9/responsive_peak/images/icon_anonymous_message.png)
