Intel® High Level Design
722 Discussions
Sample project with RTL module library not working
messn036
Hello Intel Support,
I am attempting to compile a library of RTL components to use in my HLS project.
The HLS project compiles when testing for x86-64 simulation, but the compiler complains about the desired RTL function being "undefined" when attempting to compile for test-fpga.
I have included the relevant files .v and .xml files, but cannot upload the .cpp or .h file though they are included when I compile the library
I am curious as to which file likely has the issue since I can do simulation but not compilation.
Thank you in advance
messn036
The issue is in my expHBU.h file. I put
uint8_t expHBU(uint8_t input);
Rather than the CORRECT
extern "C" {
This extern is extremely esoteric and should be included in the reference manual.
YoshiakiS_Altera
Hello messn036,
For investigation, could you please upload your failure log?
 Yoshiaki Saito
messn036
i++ component_testbench.cpp expHBU.a -v --dont-error-if-large-area-est -march=Cyclone10GX -o test-fpga
Target FPGA part name: 10CX220YF780I5G
Target FPGA family name: Cyclone10GX
Target FPGA speed grade: -5
Resolved expHBU.a to /home/grads/messn036/OpenCL-HUBERT/OpenCL-HUBERT/component_ip/expHBU.a
Analyzing component_testbench.cpp for testbench generation
Creating x86-64 testbench
Analyzing component_testbench.cpp for hardware generation
Verifying version information in the included files.
Expecting version 21.2.0.67.4 for all included files.
Included files passed version check. Checked: /home/grads/messn036/OpenCL-HUBERT/OpenCL-HUBERT/component_ip/expHBU.a
Preprocessing FPGA Libraries
Optimizing component(s) and generating Verilog files
component_testbench.cpp:9: Compiler Error: undefined reference to 'expHBU(unsigned char)'
HLS Main Optimizer FAILED.
make: *** [test-fpga] Error 1
I have done some basic troubleshooting in the meantime an narrowed down my error a bit. To compile the RTL library, I am using the following commands
fpga_crossgen exp_wrapper.xml --target hls --emulation_model expHBU.cpp -o expHBU.o
fpga_libtool --target hls --create expHBU.a expHBU.o
But It seems like I need to use different flags to get the xml and verilog to compile for NOT the x86-64 simulation but for the test-fpga version. Am I right here? When should I expect to compile the xml and verilog?
messn036
Additional information: If I compile the library with just the fpga_crossgen command (exclude the expHBU.a step)
And then attempt a -march=Cyclone10GX compile
i++ component_testbench.cpp expHBU.o  -v --dont-error-if-large-area-est -march=Cyclone10GX -o test-fpga
I get the following error
Compiler Error: Cannot find Library file ./test-fpga.prj/spec.xml
YoshiakiS_Altera
Hello messn036,
Thank you for sharing the failure log with us.
I think the simple design is necessary to investigate it for us.
So could you share simple full design which can duplicate the error with us?
 Yoshiaki Saito
messn036
Here are the source files I am using. I am trying to model the basic rtl library tutorial the best I can (which compiles fine in my environment). I'm sure its some easy syntax error that none of the compilers or packagers is catching.
I cannot upload the .cpp and .h files because this site rejects them. Here is the source
expHBU.h
#include <stdint.h>
#include "HLS/math.h"
expHBU.cpp
#include "expHBU.h"
uint8_t expHBU(uint8_t input){
    return (uint8_t)exp(input);
#include "HLS/hls.h"
#include "HLS/stdio.h"
#include "expHBU.h"
component uint8_t executeexp(uint8_t exponent)
    return expHBU(exponent);
component uint8_t executeexp_basic(uint8_t exponent)
    return exp(exponent);
int main()
    uint8_t exponent = 3;
    uint8_t result = executeexp(exponent);
    printf("result %d \n", result);
    return 0;
Reminder: the x86 simulation works, but the FPGA compile does NOT
messn036
messn036
extern "C" {
YoshiakiS_Altera
Hello messn036,
Thank you for the update.
Basically, you need to add the extern “C” to call a function from C++ to C. This is general rule of C++.
C++ Language adds a prefix to a function name to support the class feature.
But, this feature is disabled when you add extern “C”.
So many C/C++ headers include:
#ifdef __cplusplus
extern "C" {
#endif
rtl_inet_uint16 rtl_htons(rtl_inet_uint16 hostshort);
rtl_inet_uint16 rtl_ntohs(rtl_inet_uint16 netshort);
rtl_inet_uint32 rtl_htonl(rtl_inet_uint32 hostlong);
rtl_inet_uint32 rtl_ntohl(rtl_inet_uint32 netlong);
#ifdef __cplusplus
#endif
 Yoshiaki Saito
YoshiakiS_Altera
Hello messn036,
I will close this thread if no further questions from you.
 Yoshiaki Saito
