Intel® High Level Design
722 Discussions
Support for bitwise operations using OpenCL?
mvemp
Does openCL map gate level operations to FPGA logic? There seems to be no 1-bit data types at the moment.
It will interesting to see bitwise operations to support for effective implmentation XNOR-neural-networks.
HRZ
Valued Contributor III
You can probably use the "bool" datatype or use "char" and mask out the unnecessary bits. Though this could result in some extra area overhead compared to a pure HDL design depending on how smart the compiler/mapper is in handling the operations.
