Intel® High Level Design
722 Discussions
a10_ref BSP not compatible with Ubuntu 18.04
DongWang-BJTU
I am trying to compile the linux driver for a10_ref BSP on a Ubuntu 18.04 machine. the following error shows up:
aocl install: Adding the board package /home/ic611/intelFPGA_pro/19.3/hld/board/a10_ref to the list of installed packages
Installing the board package driver to the system.
aocl install: Running install from /home/ic611/intelFPGA_pro/19.3/hld/board/a10_ref/linux64/libexec
Looking for kernel source files in /lib/modules/5.0.0-37-generic/build
Using kernel source files from /lib/modules/5.0.0-37-generic/build
Building driver for BSP with name a10_ref
make: Entering directory '/usr/src/linux-headers-5.0.0-37-generic'
 CC [M] /tmp/opencl_driver_PRGftZ/aclpci_queue.o
 CC [M] /tmp/opencl_driver_PRGftZ/aclpci.o
/tmp/opencl_driver_PRGftZ/aclpci.c: In function ‘aclpci_irq’:
/tmp/opencl_driver_PRGftZ/aclpci.c:340:54: error: passing argument 2 of ‘send_sig_info’ from incompatible pointer type [-Werror=incompatible-pointer-types]
      int ret = send_sig_info(aclpci->signal_number, &aclpci->signal_info, aclpci->user_task);
In file included from /tmp/opencl_driver_PRGftZ/aclpci.c:53:0:
./include/linux/sched/signal.h:325:12: note: expected ‘struct kernel_siginfo *’ but argument is of type ‘struct siginfo *’
 extern int send_sig_info(int, struct kernel_siginfo *, struct task_struct *);
cc1: some warnings being treated as errors
scripts/Makefile.build:284: recipe for target '/tmp/opencl_driver_PRGftZ/aclpci.o' failed
make[1]: *** [/tmp/opencl_driver_PRGftZ/aclpci.o] Error 1
Makefile:1614: recipe for target '_module_/tmp/opencl_driver_PRGftZ' failed
make: *** [_module_/tmp/opencl_driver_PRGftZ] Error 2
make: Leaving directory '/usr/src/linux-headers-5.0.0-37-generic'
aocl install: failed.
aocl install: Removing FCD
aocl install: Removing the board package /home/ic611/intelFPGA_pro/19.3/hld/board/a10_ref from the list of installed packages
I think the driver is not compatible with linux kernel 5.0 yet. Hope this issue could be fixed for Ubuntu 18.04 as it is said to be supported. Both v19.1 and v19.3 SDK were tested.
STyur
MEIYAN_L_Intel
I will check internally this information with Linux Driver Developer.
I will reply here when the developer reply to me.
STyur
Hi!
I resolve this issue. Please read:
https://forums.intel.com/s/question/0D70P000006ShqPSAS
