Intel® High Level Design
722 讨论
a10_ref BSP not compatible with Ubuntu 18.04
DongWang-BJTU
新分销商 I
2,014 次查看
I am trying to compile the linux driver for a10_ref BSP on a Ubuntu 18.04 machine. the following error shows up:
aocl install: Adding the board package /home/ic611/intelFPGA_pro/19.3/hld/board/a10_ref to the list of installed packages
Installing the board package driver to the system.
aocl install: Running install from /home/ic611/intelFPGA_pro/19.3/hld/board/a10_ref/linux64/libexec
Looking for kernel source files in /lib/modules/5.0.0-37-generic/build
Using kernel source files from /lib/modules/5.0.0-37-generic/build
Building driver for BSP with name a10_ref
make: Entering directory '/usr/src/linux-headers-5.0.0-37-generic'
 CC [M] /tmp/opencl_driver_PRGftZ/aclpci_queue.o
 CC [M] /tmp/opencl_driver_PRGftZ/aclpci.o
/tmp/opencl_driver_PRGftZ/aclpci.c: In function ‘aclpci_irq’:
/tmp/opencl_driver_PRGftZ/aclpci.c:340:54: error: passing argument 2 of ‘send_sig_info’ from incompatible pointer type [-Werror=incompatible-pointer-types]
      int ret = send_sig_info(aclpci->signal_number, &aclpci->signal_info, aclpci->user_task);
In file included from /tmp/opencl_driver_PRGftZ/aclpci.c:53:0:
./include/linux/sched/signal.h:325:12: note: expected ‘struct kernel_siginfo *’ but argument is of type ‘struct siginfo *’
 extern int send_sig_info(int, struct kernel_siginfo *, struct task_struct *);
cc1: some warnings being treated as errors
scripts/Makefile.build:284: recipe for target '/tmp/opencl_driver_PRGftZ/aclpci.o' failed
make[1]: *** [/tmp/opencl_driver_PRGftZ/aclpci.o] Error 1
Makefile:1614: recipe for target '_module_/tmp/opencl_driver_PRGftZ' failed
make: *** [_module_/tmp/opencl_driver_PRGftZ] Error 2
make: Leaving directory '/usr/src/linux-headers-5.0.0-37-generic'
aocl install: failed.
aocl install: Removing FCD
aocl install: Removing the board package /home/ic611/intelFPGA_pro/19.3/hld/board/a10_ref from the list of installed packages
I think the driver is not compatible with linux kernel 5.0 yet. Hope this issue could be fixed for Ubuntu 18.04 as it is said to be supported. Both v19.1 and v19.3 SDK were tested.
0 项奖励
1 解答
STyur
新分销商 I
1,834 次查看
0 项奖励
2 回复数
MEIYAN_L_Intel
1,834 次查看
I will check internally this information with Linux Driver Developer.
I will reply here when the developer reply to me.
0 项奖励
STyur
新分销商 I
1,835 次查看
Hi!
I resolve this issue. Please read:
https://forums.intel.com/s/question/0D70P000006ShqPSAS
0 项奖励
回复
