Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
AVX-512 in graph process applications
ilya_a_
Hello, everyone!
I'm currently researching possibilities of graph algorithm implementations using vector instructions (working in KNL and using AVX-512) and need some help and advice. The first algorithm I tried to implement was Bellman-Ford for shortest paths computations. It's multicore version is relatively easy:
    bool changes = true;
    #pragma omp parallel num_threads(omp_threads)
        // do bellman-ford algorithm
        while (changes)
            #pragma omp barrier
            changes = false;
            #pragma omp barrier
            #pragma omp for schedule(static)
            for (long long cur_edge = 0; cur_edge < edges_count; cur_edge++)
                int src = src_ids[cur_edge];
                int dst = dst_ids[cur_edge];
                _TEdgeWeight weight = weights[cur_edge];
                _TEdgeWeight src_distance = _distances[src];
                _TEdgeWeight dst_distance = _distances[dst];
                if (dst_distance > src_distance + weight)
                    _distances[dst] = src_distance + weight;
                    changes = true;
            #pragma omp barrier
So we get data (source vertex id, destination vertex id and weight) about each graph edge from memory, and try to update distances array with data loaded (which is initially set to inf).
AVX version of this code is bit more complicated:
    __mmask16 *changes_mask = new __mmask16[omp_threads];
        while (changes)
            #pragma omp barrier
            changes = false;
            int thread_id = omp_get_thread_num();
            changes_mask[thread_id] = false_mask;
            #pragma omp barrier
            for (int i = 0; i < (edges_count / 16); i++)
                __m512i src_avx = _mm512_load_si512(&src_ids_ptrs);
                __m512i dst_avx = _mm512_load_si512(&dst_ids_ptrs);
                __m512 weight_avx = _mm512_load_ps(&aligned_weights[16*i]);
                __m512 src_distance_avx = _mm512_i32gather_ps(src_avx, aligned_distances, 4);
                __m512 dst_distance_avx = _mm512_i32gather_ps(dst_avx, aligned_distances, 4);
                __m512 new_distance_avx = _mm512_add_ps(src_distance_avx, weight_avx);
                __mmask16 cmp_result_mask = _mm512_cmp_ps_mask(new_distance_avx, dst_distance_avx, _MM_CMPINT_LT);
                changes_mask[thread_id] = _mm512_kor(changes_mask[thread_id], cmp_result_mask);
                _mm512_mask_i32scatter_ps(aligned_distances, cmp_result_mask, dst_avx, new_distance_avx, 4);
            #pragma omp barrier
            CPUmask check_changes = { changes_mask[thread_id] };
            if((check_changes.a[0] != 0)|| (check_changes.a[1] != 0))
                changes = true;
            #pragma omp barrier
It looks pretty efficient to me (we exchanged 16 usual instructions for 1 vector in each line of the code), and it works correct (same distances result);
BUT, on tests it demonstrates NO acceleration, and, in fact, decreases performance. Here are some timing results:
using 1 threads
avx time : 119.692 sec
usual time: 99.2013 sec
using 68 threads
avx time : 7.49615 sec
usual time: 2.62707 sec
I hope you can provide any ideas why this performance decrease happens and how can I avoid it. Thank you for your help!
jimdempseyatthecove
Ilya,
Your first (simplified) code example has an error and inefficiencies. The following should be a better simplified example:
    while (changes)
        ! *** unnecessary barrier
        ! *** #pragma omp barrier
        changes = false;
        #pragma omp barrier  ! (necessary)
                ! *** multiple threads may have reached the same conclusion
                #pragma omp critical
                    changes = true;
        ! barrier is implicit on omp for
The following *** untested *** intrinsic code might be better:
__mmask16 changes_mask = true_mask; // copy for all threads
    int thread_id = omp_get_thread_num();  // inside parallel region, outside loop
    while (changes_mask)
        changes_mask = false_mask;
        #pragma omp barrier
        #pragma omp for schedule(static) reduction(|:changes_mask)
            changes_mask = _mm512_kor(changes_mask, cmp_result_mask);
Note, you may have issues with the type for changes_mask.
Also note: See if you can rearrange the data such that you can avoid use of gather and scatter.
Jim Dempsey
JWong19
Could you share your test data so that one could test it? It seems that performance decrease is due to data race.
You may consider to have at most 1 thread to update each element of the '_distance' array in each iteration......
