Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1135 Discussions
Executed instruction not valid for specified chip (PENTIUM4)
JWong19
I encounter the following error message with the latest version (7.39-win) of Intel SDE, when I attempt the "-p4" switch. What is the preferred way of using the "-p4" switch?
TID 0 SDE-ERROR: Executed instruction not valid for specified chip (PENTIUM4): 0x7ffbaa344fa2: syscall
Image: C:\WINDOWS\SYSTEM32\ntdll.dll+0xa4fa2
Function: ZwSetEvent
Instruction bytes are: 0f 05
The message shows up before the first line of my simple console program. I am on Windows 10 Home and Visual Studio 2015 community edition.
MarkC_Intel
Try "-chip-check-exe-only" (no quotes).  When simulating older processors you will encounter "newer" instructions in thing that are out of your compilation control (system runtime libraries, etc.)
MarkC_Intel
JWong19
Thanks, it works! However, the program unexpectedly exits at a MOVSXD instruction in x64 build......
48 63 40 04  movsxd rax, dword ptr [rax+0x4]
