Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
From Gulftown to Sandy Bridge
Cryptographer
Though I am aware that this is not a forum for hardware recommendations I am a clueless where else to ask.
As I want to build up a new system with a processor capable of the WestmereAES-NI instructions, which socket is the right choice to later replace the processor with anAVX capable one?
My current favorite is a Tyan S7025 having two LGA1366 sockets. Will therebe a compatible AVX CPU for that in the next years?
knujohn4
According to this site: http://www.bit-tech.net/hardware/cpus/2010/04/21/intel-sandy-bridge-details-of-the-next-gen/1
Sandy bridge"... will be split into two markets: mainstream and enthusiast. The mainstream models will replace the current LGA1156 'H1' Clarkdale and Lynnfield CPUs (Core i3 and Core i5) and will use LGA1155 'H2' packaging."
I am not sure if LGA1366 and LGA1156 is compatible, but I would guess not.
It was not easy finding any good info on Intel's sites!
Knut
Cryptographer
Thank you for the veryinteresting link.
In the comment section a bit-tech deputy editor appended "LGA1366 and X58 will still be around for quite a while, so it's still a good upgrade. P55/H55 on the other hand has a much shorter shelf life now."
On the other side, I could find at http://en.wikipedia.org/wiki/Intel_Sandy_Bridge_(microarchitecture) a list with anLGA 1356 socket instead of the LGA 1366, both with three DDR3 interfaces. (No comment about compatibility.)
Until Intel does notclarify whether their products will remain compatible I think I should better wait, or completely skip the Gulftown generation and remain happy with my current dual 604 system.
