Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
Function declaration parameters - asm.
srimks
New Contributor II
For below HLL source code function declaration -
void apple( const State now,
Real crd[MAX_ATOMS][SPACE],
const Real v[MAX_TORS][SPACE],
const int tlist[MAX_TORS][MAX_ATOMS],
const int ntor )
The ICC-v11.0 assembly for above function declaration is as below -
# parameter 1(now): 112 + %rsp
# parameter 2(crd): %rdi
# parameter 3(v): %rsi
# parameter 4(tlist): %rdx
# parameter 5(ntor): %ecx----
Now, how do I represent above asm parameters as shown by assembly file as above in user defined Inline SSE assembly?
Can I have some Intel C++ Compiler references/documents which discuss, how to interpret, analyze and write Inline SSE assembly code for IA-64 on Linux x86_64?
~BR
neni
New Contributor II
It's not clear exactly what you are trying to do. The parametrs passing, which registers to use etc are being defined by the ABI (application binary interface), which is different between OS (and calling conventions, etc). For inline asm, the C symbols are accesible from within the inline asm block (in most case, the compiler will dump them from registers to their designated stack location and load them from the stack). If all you want is basic SSE functionality you might consider using compiler intrinsics over inline asm
srimks
New Contributor II
Quoting - neni
Sorry, for asking this questions. I think I am done. Thanks for your inputs.
~BR
