Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1135 Discussions
How many info could I get to estimate DRAM bandwidth?
hchen229
I am now working on a work to estimate the active time of DRAM. How could I get info about memory access times by cpu?
Thanks a lot!
Roman_D_Intel
In order to measure current DRAM bandwidth on Intel Core i7 or Xeon 5500 Series Platforms you use Intel PTU utility as described here.
Roman
