Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1150 Discussions
How to count every repeat string instruction as a single instruction when relog pinball?
Huajing-Young
When generating region pinball with Intel® Software Development Emulator (Intel® SDE), how can I make sure the sde counts every repeat string instruction as a single instruction and ignores all the internal iterations?
For example: there is a region pinball which contains 2M instructions(start:icount:8000000,stop:icount:10000000), while 20k of them are separated rep instructions. I want to generate a new region pinball which has the same start:icount and stop:icount, but counts every repeat string instruction as a single instruction and ignores all the internal iterations.
thank you very much!
@AdyT_Intel
AdyT_Intel
By default Intel SDE controller counts every repeat iteration as an instruction count.
The controller provides an option to count every repeat string instruction as a single count and skip the internal repeat counts.
Use the instcount alarm type as in start:instcount:8000000,stop:instcount:10000000.
You can get both counts with the icount tool when adding the -icount-norep knob.
More information is available in the documentation inside the kit under the doc directory.
