Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
IA32_PERF_CTL on X64 error
Matt_S_3
ビギナー
5,200件の閲覧回数
I have a problem using wrmsr IA32_PERF_CTL,  in kernel space I get a STATUS_PRIVILEGED_INSTRUCTION exception and Windbg, which has a wrmsr function, reports "no such msr".  This is on an i5-2410M  CPU.
The same code and Windbg do not generate errors on another test platform.  What could be the cause of this?
By the way rdmsr IA32_PERF_STS  works OK on both platforms.
0 件の賞賛
26 返答(返信)
Matt_S_3
ビギナー
899件の閲覧回数
Hi
It says this: "State transitions are initiated by writing a 16-bit value to the IA32_PERF_CTL register" which implies only eax is written to.  However IA32_PERF_CTL reads both edx and eax:   For example to turn off 'Turbo' mode bit 1 of edx needs to be set.
It seems that on the 32 bit processor on which the exception does not occur the code behind wrmsr does not care if edx is set to its existing value, ie, unchanged after doing a rdmsr.
However on the 64 bit platofrm with the exception it seems bits 1-31 of edx must be explicitely cleared before wrmsr is run.
Bernard
高評価コントリビューター I
899件の閲覧回数
>>>However on the 64 bit platofrm with the exception it seems bits 1-31 of edx must be explicitely cleared before wrmsr is run>>>
Thanks for that info.
Bernard
高評価コントリビューター I
899件の閲覧回数
I have been investigating the issue with the debugger error "no such msr" and I have found that some of the msr registerd can not be written from ring0 code.They are accessible only from SMM mode.It could be accessed for example from BIOS code by writing to I/O port 0x0B2.
Bernard
高評価コントリビューター I
899件の閲覧回数
Bernard
高評価コントリビューター I
899件の閲覧回数
Bernard
高評価コントリビューター I
899件の閲覧回数
Sorry for multiple posts I thought that this is IDZ website issue.
返信
