Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
Intel TSX with STAMP benchmark
YangHun_P_
when running vacation application in stamp benchmark, there are several code defined as TM_RESTART.
First, i think that it would be okay that _xabort will restart the transactions.
But, when the transaction fails to commit, it should goes to fallback path with a lock. In this case how to go back to the _xbegin when transaction should be restarted?
Roman_D_Intel
xabort instruction has a constant 8-bit argument that is passed to the transaction abort handler (see the abort status returned by _xbegin() intrinsic: the upper 8 bits [24:31]). For TM_RESTART you can define a special constant value that can be recognized in your abort handler and handled appropriately (i.e. restart transaction, do not take the fall-back lock).
Roman
