Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
Larrabee will support SSE or not?
maa1
Larrabee will be compatible with SSE/SSE2/SSE3/SSE4 code or not?
TimP
Quoting - maa1
A different instruction set
levicki
Valued Contributor I
Quoting - tim18
What kind of answer is this?
srimks
New Contributor II
Quoting - Igor Levicki
God and none other than Tim knows?
Matthias_Kretz
Quoting - maa1
See here for the SIMD instructions Larrabee will provide: http://software.intel.com/en-us/articles/prototype-primitives-guide/
You can guess how much sense it would make to support another (a lot less powerful) SIMD instruction set when there is no code that is binary compatible anyway.
BTW, if you want to write code that can use the SSE instructions on CPUs as well as the LRBni on Larrabee you should take a look at http://gitorious.org/vc
