Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
Loops inside transactional regions in RTM (TSX)
jsg
Hi everyone,
I have a question about loops in TSX. Can I put loops inside a transactional region?
Example
xbegin();
   while(cond) i++;
xend();
Thank you very much,
AdyT_Intel
Yes, you can put conditional code and loops inside a transaction.
jimdempseyatthecove
I might add, if you use temporary variables, initialize them prior to entering the transaction, and then re-initialize them to same value before exit of transaction. The elison functionality will then void all writes to the temporary variable (inside the transaction).
Jim Dempsey
