Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
PUSH instruction in 64 bit mode
logicman112
How CPU differentiates between the following instructions while it is in IA-32e, 64 bit, long mode :
PUSH r/m16
PUSH r/m64
While the opcode for both is FF/6, they have the same code segment descriptor, no prefixes were used and the default operand size attribute is 8 or 32 bits?!!
neni
New Contributor II
you have only two flavors 16 bit and 64 bit, 66 prefix is what seperates them
from the manual:
In 64-bit mode, the instructions default operation size is 64 bits. In a push, the
64-bit RSP register (stack pointer) is decremented by 8. A 66H override causes
16-bit operation. Note that pushing a 16-bit operand can result in the stack pointer
misaligned to 8-byte boundary.
logicman112
thank you to answer the question
