Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1145 Discussions
Problems encountred during vectorization of code using SSE intrinsics
priyanka06
I have been struggling with vectorizing a particular application for sometime now and I have tried everything. From autovectorization, to handcoded SSE intrinsics. But somehow I am unable to obtain speedup on my stencil based application.
Following is a snippet of my current code, which I have vectorized using SSE intrinsics.
//#pragma ivdep
for ( i = STENCIL; i < z - STENCIL; i+=4 )
it = it2 + i;
__m128 center = _mm_mul_ps(_mm_load_ps(&p2[it]),C00_i);
u_j4 = _mm_load_ps(&p2[i+j*it_j-it_j4+k*it_k]); //Line 180
u_j3 = _mm_load_ps(&p2[i+j*it_j-it_j3+k*it_k]);
u_j2 = _mm_load_ps(&p2[i+j*it_j-it_j2+k*it_k]);
u_j1 = _mm_load_ps(&p2[i+j*it_j-it_j +k*it_k]);
u_j8 = _mm_load_ps(&p2[i+j*it_j+it_j4+k*it_k]);
u_j7 = _mm_load_ps(&p2[i+j*it_j+it_j3+k*it_k]);
u_j6 = _mm_load_ps(&p2[i+j*it_j+it_j2+k*it_k]);
u_j5 = _mm_load_ps(&p2[i+j*it_j+it_j +k*it_k]);
__m128 tmp2i = _mm_mul_ps(_mm_add_ps(u_j4,u_j8),X4_i);
__m128 tmp3 = _mm_mul_ps(_mm_add_ps(u_j3,u_j7),X3_i);
__m128 tmp4 = _mm_mul_ps(_mm_add_ps(u_j2,u_j6),X2_i);
__m128 tmp5 = _mm_mul_ps(_mm_add_ps(u_j1,u_j5),X1_i);
__m128 tmp6 = _mm_add_ps(_mm_add_ps(tmp2i,tmp3),_mm_add_ps(tmp4,tmp5));
__m128 tmp7 = _mm_add_ps(tmp6,center);
_mm_store_ps(&tmp2,tmp7); //Line 196
When I compile (icc) the above code without #pragma ivdep I get the following message: remark: loop was not vectorized: existence of vector dependence. vector dependence: assumed FLOW dependence between tmp2 line 196 and tmp2 line 196.
vector dependence: assumed ANTI dependence between tmp2 line 196 and tmp2 line 196.
When I compile (icc) it with the #pragma ivdep, I get the following message: remark: loop was not vectorized: unsupported data type. //Line 180
Why is there a dependence suggested for Line 196? How can I eliminate the suggested vector dependence?
Thomas_W_Intel
When you already have vectorized the code with intrinsics, the compiler cannot auto-vectorize it: You already have done the vectorization. If you want to investigate in auto-vectorization, you have to go back to the scalar version.
jimdempseyatthecove
Consider writing your sse intrinsics to use fewer temps and to interleave the loads with the multiplys Jim Dempsey
