Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
SDE 7.15 for Linux has no 64-bit libs
andysem
New Contributor III
The recently released SDE 7.15 for Linux seem to have 32-bit libraries instead of 64-bit in intel64/pin_ext_lib and intel64/xed_ext_lib. Is this an oversight or am I missing something?
AdyT_Intel
Yes, you are right, apparently we modified our build system and these libraries are not really used which open the door for this mismatch.
We will fix this soon.
AdyT_Intel
I updated the kit with the right libraries. The mismatch in the older version only affected the xed64 tool.
andysem
New Contributor III
Thanks, the updated archive contains the correct libraries.
