Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
SDE fails to run a process
Harald_S_Intel
  I'm running SDE 7.49 on a machine with the following characteristics
  # uname -a
  Linux login3 3.0.101-0.35-default #1 SMP Mon Oct 31 15:43:41 CET 2016 x86_64 x86_64 x86_64 GNU/Linux
  # grep "model name" /proc/cpuinfo
  model name      : Intel(R) Xeon(R) CPU E5-2670 0 @ 2.60GHz
  but when I try to submit the following command, then SDE fails
   # /opt/intel/sde/7.8.0/sde64 -- /bin/ls
   Killed
   E: Attach to pid 20906 failed: No such file or directory
  Any idea on what might be wrong or what can be checked?
Thank you
MICHAEL_G_Intel1
Hi Harold
Since you are intel employee can you please send a mail to sde-dev ?
The error you get is very strange since you do not do attach.
Can you please add -echo knob to SDE?
Michael
