Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
SDE on MacOS 10.15
Zohar__Ronen
ビギナー
2,807件の閲覧回数
I used SDE on MacOS 10.14, once upgraded to 10.15 (Catalina) sde64 barfs with the message below.
Is this a known issue? any workaround?
Ronen
A: Source/pin/injector_u/loadercommands.cpp: NotifyOnMiniloaderFailure: 667: Injector: caught unexpected signal 10 while running miniloader on file XXXXX
## STACK TRACE
Pin must be run with tool in order to generate Pin stack trace
Detach Service Count: 1
Pin: pin-3.8-97896-e83b36f
Copyright (c) 2003-2019, Intel Corporation. All rights reserved.
Abort trap: 6
0 件の賞賛
7 返答(返信)
AdyT_Intel
モデレーター
2,807件の閲覧回数
We are working to add the support for MacOS 10.15 and plan to release it in our next SDE release.
Zohar__Ronen
ビギナー
2,807件の閲覧回数
Is 8.50 release suppose to work? Because it’s not working for me
AdyT_Intel
モデレーター
2,807件の閲覧回数
Intel SDE release 8.50 supports mac OS 10.15, but remember to disable SIP.
Zohar__Ronen
ビギナー
2,807件の閲覧回数
Thanks Ady, SIP was re-enabled after the upgrade to 10.15. disabling it again solved the issue with release 8.50
Miller__E
ビギナー
2,807件の閲覧回数
removed
Miller__E
ビギナー
2,807件の閲覧回数
removed
Miller__E
ビギナー
2,807件の閲覧回数
removed
返信
