Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
SDE: ssc-marks and multiple mix output
Othman_B_Intel
Dear developers, I would like to use the ssc-marks as follow: for (…){ //ssc_mark_start … //ssc_mark_end } Is there a way to get the statistics for each iteration of the loop? Last time I've used SDE, the statistics of the marked region was collected only one time. Is this still the case? Thanks. Regards, Othman.
