Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
SSE3 and onwards support...
srimks
New Contributor II
If I do "less /proc/cpuinfo", I get -
model name : Intel Xeon CPU X5365 @ 3.00GHz
stepping : 11
cpu MHz : 3000.111
cache size : 4096 KB
physical id : 0
siblings : 4
core id : 0
cpu cores : 4
fpu : yes
fpu_exception : yes
cpuid level : 10
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm
syscall lm pni monitor ds_cpl est tm2 cx16 xtpr lahf_lm
which means "Intel Xeon CPU X5365" supports SSE till sse2.
How to have SSE3 onwards supports on Linux x86_64 with this processor with ICC as -
$ icpc -V
Intel C++ Intel 64 Compiler Professional for applications running on Intel 64, Version 11.0 Build 20081105 Package ID: l_cproc_p_11.0.074
Copyright (C) 1985-2008 Intel Corporation. All rights reserved.
FOR NON-COMMERCIAL USE ONLY
~BR
TimP
Go ahead and use SSE3 if you like. The fact that SSE2 is supported doesn't exclude SSE3 and SSSE3, although the latter tends to handicap those more recent CPUs which accept it.
