Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1138 Discussions
To get number of logical processors using CPUID instruction
hyunsoo
Hi all,
I have Intel i9-10900 CPU equipped with 20 logical processors. It shows exactly 20 cores in 'htop' command but, `cpuid` instruction says that I have only 16 logical processors.
I ran the cpuid instruction like below.
asm volatile
("cpuid" : "=a" (regs[0]), "=b" (regs[1]), "=c" (regs[2]), "=d" (regs[3])
: "a" (i), "c" (0));
Could you give any comment?
McCalpinJohn
To make sure you are using the CPUID instruction correctly, I recommend http://www.etallen.com/cpuid.html as a reference.
McCalpinJohn
