Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
To use FPU
GHui
The following code is to use FPU. I run it on E5-2620. It only upto 2 GFlops. If I want to 2*8 GFlops, how could I code program?
Any help will be appreciated.
void* test_pd_avx()
  double x[4]={12.02,14.34,34.23,234.34};
  double y[4]={123.234,234.234,675.34,3453.345};
  __m256d mx=_mm256_load_pd(x);
  __m256d my=_mm256_load_pd(y);
  for(;;)
    __m256d mz=_mm256_mul_pd(mx,my);
The Compiler Option: icc test.c -O0
Bernard
Valued Contributor I
Ok:)
SergeyKostrov
Valued Contributor II
>>...The Compiler Option: icc test.c -O0 Try performance evaluations with -O2 and -O3 compiler options.
GHui
-O2 or -O3 will optimize the code, and it's behavior undefined.
