Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1135 Discussions
Unable to generate Vectorization report in icc/icpc compilers.(icc -vec-report1 p1.c )
parmar__nirav
when i executed the icc command i got following error message :
$ icc -vec-report2 p1.c
icc: command line remark #10148: option '-vec-report2' not supported
even i am unable to pass flags for sse,avx.
what is couse for generation of this error, why it is not generating report and instead showing error that  -vec-report2 is not supported?
fu__jiawei
try this command: icc -qopt-report -qopt-report-phase=vec
fu__jiawei
try this command: $ icc -qopt-report -qopt-report-phase=vec
