Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1135 Discussions
Update the SDE MSVS debugger install kit to support VS2017?
Ens__John
When will the SDE debugger for MS Visual Studio be upgraded from VS2015 to VS2017?  I am currently using VS2017 to compile the AVX code and VS2015 with the SDE debugger installed to debug.  My CPU supports AVX, but not AVX2 or AVX-512.  Using VS2015 to debug works fine for AVX and AVX2 code, however it does not work with AVX-512 code, which VS2015 does not understand.  I am able to run to break points, but I cannot single step through the code.
AdyT_Intel
The VS2017 debugging support is under development and we will provide it when ready.
