Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
Updated ISE doc, rev 25 & PCOMMIT change blog
MarkC_Intel
Revision 25 of the instruction set extension document was released, now including a change-log.
http:///www.intel.com/software/isa
A blog post describes the background for the change of the proposed PCOMMIT instruction.
andysem
New Contributor III
MarkC_Intel
I fixed the short link mentioned in the original note. Thanks for mentioning it. The link dialog in the editor for this site does funky things if you paste a URL as your link text.
andysem
New Contributor III
Are there any details about the new instruction set extensions added in the new document? In particular, I'm interested in AVX512_4VNNIW and AVX512_4FMAPS.
MarkC_Intel
More details will soon be published in an upcoming revision of the document.
