Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
constants in SIMD inline assembly
Smart_Lubobya
how do i add a constant toeach elementin an array?see snipet codes
#include "stdafx.h"
#include
#include
#include "xmmintrin.h"
using namespace std;
int _tmain(int argc, _TCHAR* argv[])
int x[4][4]={1,1,1,1,2,2,2,2,3,3,3,3,4,4,4,4}; //source or input
int y[4][4];//destination or output
int b[4] ={5,5,5,5};// constants to be added
int f0,f1,f2,f3;
__asm
mov eax,x
mov ecx,b
mov edi,y
//stage one
movq mm0,[eax]
movq mm7,[ecx]
paddw mm0,mm7
movq [f0],mm0
movq mm1,[eax+8]
paddw mm1,mm7
movq [f1],mm1
movq mm2,[eax+16]
paddw mm2,mm7
movq [f2],mm2
movq mm3,[eax+24]
paddw mm3,mm7
movq [f3],mm3
//stage two
movq mm0,[f0]
psraw mm0,6
movq [edi],mm0
movq mm1,[f1]
psraw mm1,6
movq [edi+8],mm1
movq mm2,[f2]
psraw mm2,6
movq [edi+16],mm2
movq mm3,[f3]
psraw mm3,6
movq [edi+24],mm3
for (int i = 0; i < 4; i++)
for (int j = 0; j < 4; j++)
cout << y << " ";
cout << endl;
return 0;
Max_L
Hello, I suggest you to use SSE2 with 128-bit XMM registers instead of ancient 64-bit MMX (mm0-mm7),try using intrinsics instead of assembly (e.g. you will need _mm_add_epi32() in your case) to minimize efforts or use compiler, like Intel C/C++ Compiler,which can easily auto-vectorize such constructs.I'm not sure I understand what the snippet shown is trying to achieve ... but please note that type 'int' is 32-bit, i.e. requires 4-byteof mem,and PADDD instruction to add.
-Max
