Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1143 Discussions
does this exception/interrupt handler run?
logicman112
It seems the document does not explain about this scenario for CPU, Core 2 Duo!!
If I define a nonconforming code segment with a privilege not equal to zero, it can be 2 or 1 for example as an interrupt or exception handler. For what privileges this handler can run?
nonconforming code segment with a privilege equal to zero has been explained in the manual!!(First please write about it if you know it)
