Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1138 Discussions
load/store intrinsics in MMX technology(__m64)
Smart_Lubobya
have been checking for the MMX technology load/ store intrinsic in the intel mannuals. i dont seem to see any, how is loading and /or store of arrays done in MMX Tech. of type __m64?
Brijender_B_Intel
Check MOVQ instruction. you can use it to read or write 64bit.
http://www.intel.com/Assets/PDF/manual/253666.pdf
Thomas_W_Intel
In C/C++, a normal assignment will do. However, I must admit that I don't see why you would like to use MMX these days.
Smart_Lubobya
I read the manual and thanks a lot. i however could not see the equivalent intrinsic for MOVQ in __m64 data type.
Thomas_W_Intel
There is no intrinsic as the compiler will generate movq automatically for you when loading from memory.
If you would like to combine shorter types, there are _mm_set_pi32, _mm_set_pi16, and so on.
