Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
pmovzxbd using memory operands
Christopher_H_
Is there a way to use pmovzxbd with a memory operand from intrinsics currently I have either
_mm_cvtepu8_epi32(_mm_cvtsi32(ptr[offset])); //(movd)
_mm_cvtepu8_epi32(_mm_insert_epi32(_mm_setzero_si128(),ptr[offset],0));  //(pinsrd)
The movd or pinsrd should not be needed; in assembly I can write something like
__asm{
pmovzxbd xmm0,[rax+rdx*4]
Is there a way I can make this call using intrinsics instead of assembly.
bronxzv
New Contributor II
__asm{
_mm_cvtepu8_epi32((__m128i &)ptr[offset]);
will do the trick withthe Intel compiler
andysem
New Contributor III
Doesn't pmovzxbd with a memory operand require 16-byte alignment and actually access 16 bytes?
bronxzv
New Contributor II
no, the reg,mem variant is  xmm1,m32
Christopher_H_
__asm{
Unfortunately this does not seem to work with clang, it just tries to do a full aligned __m128i load and then do the conversion.
bronxzv
New Contributor II
oughh !
something else that works well with the Intel compiler is
_mm_cvtepu8_epi32(_mm_cvtsi32_si128(ptr[offset]));
where a single vpmovzxbd reg,mem is generated
arguably  we miss an intrinsic or intrinsic signature for the reg,mem variant of vpmovzxbd, for more portable and cleaner code (AFAIK)
