Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1146 Discussions
stack around variable x, sse2 intrinsic codes
Smart_Lubobya
though the codes compiles well, the programe gives the message "run time check failure, stack around variable x", where i am doing it wrong? the output y is equally wrong. data type is short 2-D array.
//.h file
#define _SSEEXAMPLE1_H
#include
__declspec(align(16))class sseexample1
public:
void charles(__m128i *x, __m128i *y);
#endif
//.cpp file
#include "stdafx.h"
#include
#include
#include "sseexample1.h"
void sseexample1::charles(__m128i* x,__m128i* y)
int j;
__m128i p,q,s;
for (j = 0;j<4;j++)
p =_mm_loadu_si128(&x);//load row one of x
q =_mm_loadu_si128(&x[j+1]);// load row 2 of x
s = _mm_add_epi16(p,q);// add row one and two
_mm_storeu_si128(&y,s);
//main.cpp file
#include "stdafx.h"
#include
#include
#include
using namespace std;
int _tmain(int argc, _TCHAR* argv[])
short x[4][4]={1,1,1,1,2,2,2,2,3,3,3,3,4,4,4,4};
short y[4][4];
//int s[4];
sseexample1 z;
z.charles((__m128i*)x,(__m128i*)y);
for (int j = 0; j < 4; j++)
cout << y << " ";
cout << endl;
return 0;
neni
New Contributor II
in c, 2D array is kept in memory as 1D array of pointers to 1D arrays
so when reading your x value, you are actually reading a vector of pointers. try to pass to the function &x[0][0] as argument
