Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
test CPU instructions
paulsohier
(Sorry if I posted this in the wrong place, I couldnt find a better place to post this).
Iam working on a x86 emulator written in JavaScript, and I would like to have some tests on this emulator to make sure the validity of the results for instructions. Does anyone know if there is a set of instructions that checks the instructions for correctness with the x86 standard?
Bernard
Valued Contributor I
Processor will throwinvalid opcode exception.
levicki
There are no such instructions.
You can try coding your emulator based on instruction behavior description available in Intel documentation, or you could try writing a test case for the emulation of each instruction and verify the results by executing the same instruction on the CPU (that would require a lot of work though).
