Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
why MKL doesn't use the SIMD?
zhou_y_1
I have a program a.out build with MKL. I exec different command:
1.
export MKL_ENABLE_INSTRUCTIONS=AVX2;export MKL_NUM_THREADS=1;export MKL_DYNAMIC=TRUE;export OMP_NUM_THREADS=1;amplxe-cl -c hpc-performance ./a.out
The FPU Utilization is 0.0%
2.
export MKL_ENABLE_INSTRUCTIONS=AVX2;export MKL_NUM_THREADS=2;export MKL_DYNAMIC=TRUE;export OMP_NUM_THREADS=2;amplxe-cl -c hpc-performance ./a.out
The FPU Utilization is 0.6%
FP Instruction Mix
    % of Packed FP Instr.: 100.0%
        % of 256-bit: 100.0%
3. export MKL_ENABLE_INSTRUCTIONS=AVX2;export MKL_NUM_THREADS=2;export MKL_DYNAMIC=TRUE;export OMP_NUM_THREADS=2;amplxe-cl -c hpc-performance taskset -c 1,2 ./a.out
4. export MKL_ENABLE_INSTRUCTIONS=AVX2;export MKL_NUM_THREADS=2;export MKL_DYNAMIC=TRUE;export OMP_NUM_THREADS=2;amplxe-cl -c hpc-performance taskset -c 1,2,3,4,5,6 ./a.out
The FPU Utilization is 1.3%
FP Instruction Mix
    % of Packed FP Instr.: 85.7%
          % of 256-bit: 85.7%
    % of Scalar FP Instr.: 14.3%
I wonder the behavior of MKL?
