I am having a problem with ref. Below is my implementation. The forward transform works fine, I can see the 4 output images look good. The problem is with the inverse, its output (to be the same image dimensions as the input image, image is square (orgWidth==orgHeight)) has aliasing and it looks like every second row and every second column content is blank. I can't find a way to embed an output image here. Please let me know how I can get that to you in case you want to take a look.
Can you please check and see what the problem may be?
Thank you!!
IppStatus ippStatus = ippStsNoErr;
IppiWTFwdSpec_32f_C1R* pSpecFwd;
IppiWTInvSpec_32f_C1R* pSpecInv;
int specSizeFwd, specSizeInv;
Ipp32f pTapsLow[3] = { 0.25, 0.5, 0.25 };
int lenLow = 3;
int anchorLow = 1;
Ipp32f pTapsHigh[3] = { 0.75, -0.25, -0.125 };
int lenHigh = 3;
int anchorHigh = 1;
int sourceBWidth = orgWidth + 1;
int sourceBArraySize = sourceBWidth * sourceBWidth;
Ipp32f *pSrcB = new Ipp32f[sourceBArraySize];
int srcStepB = sourceBWidth * sizeof(Ipp32f);
IppiSize roiSizeB = { sourceBWidth, sourceBWidth };
int srcStep = orgWidth * sizeof(Ipp32f);
IppiSize roiSize = { orgWidth, orgWidth };
int subWidth = orgWidth / 2;
Ipp32f *pDetailXDst = new Ipp32f[subWidth * subWidth];
Ipp32f *pDetailYDst = new Ipp32f[subWidth * subWidth];
Ipp32f *pDetailXYDst = new Ipp32f[subWidth * subWidth];
Ipp32f *pApproxDst = new Ipp32f[subWidth * subWidth];
IppiSize dstRoiSize = { subWidth, subWidth };
int bufSizeFwd, bufSizeInv;
Ipp8u* pBufferFwd;
Ipp8u* pBufferInv;
IppiSize roiInvSize = { subWidth, subWidth };
int stepDstInv = orgWidth * sizeof(Ipp32f);
int subWidthPlusOne = subWidth + 1;
Ipp32f *pAppB = new Ipp32f[subWidthPlusOne * subWidthPlusOne];
Ipp32f *pXB = new Ipp32f[subWidthPlusOne * subWidthPlusOne];
Ipp32f *pYB = new Ipp32f[subWidthPlusOne * subWidthPlusOne];
Ipp32f *pXYB = new Ipp32f[subWidthPlusOne * subWidthPlusOne];
int StepB = subWidthPlusOne * sizeof(Ipp32f);
IppiSize roiInvSizeB = { (subWidth + 1), (subWidth + 1) };
int approxStep, detailXStep, detailYStep, detailXYStep;
approxStep = detailXStep = detailYStep = detailXYStep = subWidth * sizeof(Ipp32f);
//adds border to the source image
ippStatus = ippiCopyWrapBorder_32s_C1R((Ipp32s*)pSrc, srcStep, roiSize, (Ipp32s*)pSrcB, srcStepB, roiSizeB, 1, 1);
//performs forward wavelet transform
ippStatus = ippiWTFwdGetSize_32f(1, lenLow, anchorLow, lenHigh, anchorHigh, &specSizeFwd, &bufSizeFwd);
pSpecFwd = (IppiWTFwdSpec_32f_C1R*)ippMalloc(specSizeFwd);
pBufferFwd = (Ipp8u*)ippMalloc(bufSizeFwd);
ippStatus = ippiWTFwdInit_32f_C1R(pSpecFwd, pTapsLow, lenLow, anchorLow, pTapsHigh, lenHigh, anchorHigh);
ippStatus = ippiWTFwd_32f_C1R(pSrcB + roiSizeB.width + 1, srcStepB, pApproxDst, approxStep,
pDetailXDst, detailXStep, pDetailYDst, detailYStep, pDetailXYDst, detailXYStep, dstRoiSize, pSpecFwd, pBufferFwd);
/* ippStatus = ippiCopy_32f_C1R(pApproxDst, approxStep, pDst, srcStep, dstRoiSize);
ippStatus = ippiCopy_32f_C1R(pDetailXDst, approxStep, pDst + subWidth, srcStep, dstRoiSize);
ippStatus = ippiCopy_32f_C1R(pDetailYDst, approxStep, pDst + (subWidth * m_nVolLoadedX), srcStep, dstRoiSize);
ippStatus = ippiCopy_32f_C1R(pDetailXYDst, approxStep, pDst + subWidth + (subWidth * m_nVolLoadedX), srcStep, dstRoiSize);
ippStatus = ippiWTInvGetSize_32f(1, lenLow, anchorLow, lenHigh, anchorHigh, &specSizeInv, &bufSizeInv);
pSpecInv = (IppiWTInvSpec_32f_C1R*)ippMalloc(specSizeInv);
pBufferInv = (Ipp8u*)ippMalloc(bufSizeInv);
ippStatus = ippiWTInvInit_32f_C1R(pSpecInv, pTapsLow, lenLow, anchorLow, pTapsHigh, lenHigh, anchorHigh);
//adds border to four images obtained after ippiWTFwd
ippStatus = ippiCopyWrapBorder_32s_C1R((Ipp32s*)pApproxDst, approxStep, dstRoiSize, (Ipp32s*)pAppB, StepB, roiInvSizeB, 0, 0);
ippStatus = ippiCopyWrapBorder_32s_C1R((Ipp32s*)pDetailXDst, detailXStep, dstRoiSize, (Ipp32s*)pXB, StepB, roiInvSizeB, 0, 0);
ippStatus = ippiCopyWrapBorder_32s_C1R((Ipp32s*)pDetailYDst, detailYStep, dstRoiSize, (Ipp32s*)pYB, StepB, roiInvSizeB, 0, 0);
ippStatus = ippiCopyWrapBorder_32s_C1R((Ipp32s*)pDetailXYDst, detailXYStep, dstRoiSize, (Ipp32s*)pXYB, StepB, roiInvSizeB, 0, 0);
//performs inverse wavelet transform
ippStatus = ippiWTInv_32f_C1R(pAppB, StepB, pXB, StepB, pYB, StepB, pXYB, StepB, roiInvSize, pDst, stepDstInv, pSpecInv, pBufferInv);
// printf_32f_2D("After WTFinv ->\n pDstInv", pDst, roiSize, stepDstInv, ippStsNoErr);
ippFree(pSpecFwd);
ippFree(pSpecInv);
ippFree(pBufferFwd);
ippFree(pBufferInv);
Thank you Chao!
I have the Ortho4 and Ortho6 working, but the test2d is giving me trouble. Can you please explain where the 12 in
Ipp32f pSrcB[16*16];
is coming from?
Thanks!
Sorry, I meant to ask where is the 16 coming from :-)
