32 and 64 distributions on Windows
Ockham_s_Razor
I have a program written in managed code and uses the ipps dll's. In order to access a function I have to import the functions via
const string lib = "ippsem64t-5.3.dll"; // vista 64
or
const string lib = "ipps-5.3.dll"; // 32 bit os
[DllImport(lib)] public static extern void ippsZero_64f(double[] dst, int len);
What is the best way to handle using the same program on different os? (Remember this is managed code so my same EXE can run on eithr OS) I was thiniking to define
const string lib = "my-ipps-5.3.dll";
and then just rename ippsem64 or ipps to that dll at installation depending upon the operating systems.
Is this a proper method, or will I get into trouble. Also, are their better ways of dealing with this issue.
-jam
PS; Is Intel planning on supplying managed wrappers or do we have to roll our own forever.
Vladimir_Dudnik
you know in native code it is not easy to combine 32-bit and 64-bit code in single executable. To be honest I do not know the best way of doing that.
Currently we do provide an example of how to provide VB .NET or C# interface to IPP. We do not have plan to supply managed wrappers for IPP in the nearest versions. You could submit it as a feature request to Intel Premier Support.
Vladimir
