845G DirectShow base TV app Not playing rotated
jdw
I have developed an application using DirectShow that basically plays TV. It works fine until I rotate the display 90 degrees. At that point it will not play on boxes that have the Intel 845G onboard video. The error I get is the following:
Either Microsoft DirectDraw has not been installed or the video card capabilities are not suitable.
It tells me to check that I'm using 32 bit color - which i am. It works correctly with other video drivers (NVIDEA)
Does anyone have a suggestion - or is this simply not supported with the onboad 845G chipset?
