8bit and 16bit C1R to C3R
coolshashi
Hello
I need to convert the following. How can I Do this in IPP ?
1) Convert an image that has 8bit grey scale (1 component)  to 8 bit RGB (3 component) image ?
2) Convert an image that has 16bit grey scale (1 component)  to 8 bit RGB (3 component) image ?
Shashi
Chao_Y_Intel
Shanshi,
For the conversion, do you just want copy the gray image data into the RGB channel? You can check the following function:
ippiDup_8u_C1C3R
For 16bit gray image, it can first convert to 8 bit, then call the ippiDup_8u_C1C3R function.
Chao
coolshashi
Thanks. That was helpful answer.
