A possible bug in IPP function which convert YCbCr411 to RGB values
Daniel_T_2
I think there is a bug in IPP function "ippiYCbCr411ToBGR_8u_P3C4R" when it converts saturated YCbCr 411 values to RGB values. When an image is saturated, its YCbCr values are Y=235, Cb=128, and Cr=128. In this case, after conversionis done, the RGB values are all 254, instead of 255.
I am using IPP 7.0.6.278
I attached my sample codes, and the output of my sample codes are shown as below:
dst[ 0]=254
dst[ 1]=254
dst[ 2]=254
dst[ 3]=0
dst[ 4]=254
dst[ 5]=254
dst[ 6]=254
dst[ 7]=0
dst[ 8]=254
dst[ 9]=254
dst[10]=254
dst[11]=0
dst[12]=254
dst[13]=254
dst[14]=254
dst[15]=0
Does anyone else ever encounter the same issue?
Gennady_F_Intel
thanks, we will check the problem on our side.
Gennady_F_Intel
yes, this is the issue with color conversion function. the problem is escalated. i will give you know when the problem would be fixed.
Gennady_F_Intel
here is the number of this issue for tracking - DPD200305775
Gennady_F_Intel
hello, the problem has been fixed in IPP 8.0 released the last week.
Daniel_T_2
Thank you for the update.
