6832 Discussions
Access violation calling ippsExp_64fc_A53 in IPP 2018.0.124
Keith_W_
I am getting an access violation when calling ippsExp_64fc_A53 in IPP 2018.0.124
Code to reproduce:
Ipp64fc* b1{ ippsMalloc_64fc(1025) };
Ipp64fc* b2{ ippsMalloc_64fc(1025) };
for (int i = 0; i < 1025; i++)
	b1.re = 1;
	b1.im = 0;
ippsExp_64fc_A53(b1, b2, 1025);
ippsFree(b1);
ippsFree(b2);
My machine specs:
OS: Windows 10 Professional
IPP version: 2018.0.124
Processor: Intel Core i7-4790
Memory: 32 GB RAM
IDE: Visual Studio 2017 (debug build 64-bits)
The fix is to use ippsExp_64fc_A50 which works.
Keith_W_
I should add that this only occurs when I enable gflags to catch memory issues:
gflags /p /enable app.exe /full
Jonghak_K_Intel
Hi Keith,
 Can you provide a screenshot of the access violation message and some information about how gflags detects the memory issues and how it affects the working process?
thank you
Keith_W_
You can learn more about gflags here (it is part of the Microsoft Windows SDK for detecting memory leaks and buffer overruns):
https://docs.microsoft.com/en-us/windows-hardware/drivers/debugger/gflags
Screen shot of the error:
https://imgur.com/a/yKTNB
Replacing ippsExp_64fc_A53 with ippsExp_64fc_A50 resolves the problem.
Jonghak_K_Intel
Thanks for the information.
The issue has been escalated to the engineering to root cause.
We need some time to see what actually happens when gflags gets enabled.
Will get back to you as soon as possible.
Thank you.
