- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
I'm getting an access violation in ippiFilterSeparable in the following scenario: imageSize = (5,2), kernelSize = (9,9). Below is the code section :
IppiSize kernelSize{ 9,9 }; IppDataType dataType = IppDataType::ipp16s; IppDataType kernelDataType = IppDataType::ipp16s; IppiSizeL roiSize = {srcSize.width,srcSize.height}; int srcStep = srcSize.width * sizeof(uint8_t); // width = 5 int dstStep = dstSize.width * sizeof(uint8_t); //width=5 int specSize = 0; IppSizeL bufferSize = 0; ippiFilterSeparableGetBufferSize_L(roiSize, kernelSize, dataType, kernelDataType, 1 /*channels*/, &bufferSize); ippiFilterSeparableGetSpecSize_L(kernelSize, dataType, 1 /*channels*/, &specSize); //allocate pBuffer and pSpec buffers using bufferSize and specSize //.... //kernel is a vector with 9 elements ippiFilterSeparableInit_16s_L(kernel.data(), kernel.data(), kernelSize, 1, 0, dataType, 1 /*channels*/, pSpec.getBuffer()); result = ippiFilterSeparable_8u_C1R_L(pSrc, srcStep, pDst, dstStep, roiSize, IppiBorderType::ippBorderRepl, 0, pSpec.getBuffer(), pBuffer.getBuffer());
Actually the same thing is hapenning for kernels of size bigger than (3,3). This doesn't happen if the image has size (2,5) (instead of (5,2)).
Also, setting the roiSize in the following way :
IppiSizeL roiSize = { srcSize.width , std::max<int>(srcSize.height, static_cast<int>(kernel.size())) };
seems to fix the issue.
Is this the correct way of handling these scenarios ?
Thank you in advance!
Dorian
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hello Dorian,
Thanks for raising the issue! Would you mind provide your whole sample code? Then we can reproduce it and send the feedback to you.
Ruqiu
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hello Dorian,
we found a bug in the algorithm implementation. We will fix it in one of the future IPP releases. Thank you for the bug reporting. I'm sorry for the issue.
Pavel
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
