Access violation when destroying H.264 Encoder
Emmanuel_W_
In the IPP V6.0 sample for H.264 encoder, there seem to be a crash when using thedefault memory allocator. Calling the close method on the encoder will call BaseCodec:Close which will delete the memory allocator. The destructor of the H.264 encoder indirectly access the memory allocator through H264EncoderFrame_Destroy and H264EncoderFrame_deallocateParsedFrameData causing an access violation.
So if close is called before reaching the destructor of the encoder the codec will crash.
Emmanuel
Vladimir_Dudnik
Thanks for reporting onthe issue, I notified developers teamabout this.
Vladimir
Vladimir_Dudnik
Vladimir
