- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Hello All,
I just implemented the histogram equalization technique using intel ipp functions. Since Histogram equalization equalizes within the two extreem values, I was thinking of implementing other methods for auto contrast.
Is there any way that I can perform auto contrast and not histogram equlaiztion?
Sharath
Lien copié
- « Précédent
- 1
- 2
- Suivant »
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
The corrected images all seems to be Negative?
And what would be the purpose of this exercise?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I still think the images are "Negative", or "Inverted". Simply look at a few spots:
1- The ears: original has light ears on darker background, and filtered has the reverse.
2- The head: original is dark, filtered is bright.
3- The corners: original has lighter graqy corners, filter has darker gray corners.
I undestand your filters, however, in this discussion, we are talking about "fixing" the problem that parts are very bright and other parts are very dark, and how can you display both types properly at the same time. In my opinion, filtering is more about enhancing the edges, or structure, to better see detail, but that is an altogether different topic.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Anyway, I'm happy to see that you are looking at all this :)
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
If IIR processing did not make that, then what did?
I think that, for this histogram/contract/brightness discussion, we should work images that are proper.
I was not aware that my sample images were 32 bit, I intended them to be 8 bit grayscale, but I could redo them if required.
That bone structure is more visible is simply because its edges are enhanced by the filtering. However, in this discussion, we are actually talking about contract/brightness and histograms...
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I agree to your definition of Negative.
Its just that I want to ensure we talk about the same thing, since automatic optimalisation is a complex matter.
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
- « Précédent
- 1
- 2
- Suivant »
