Band Pass: FFT or conv?
erano111
I'm working with set of images, each image is 320*240 pixels, divide to 17X15 blocks (each block 16X16 pixels).
I wish to do give a "focus grade" to each block.
For now I used IPP FFT with 16X16 LP filter. Does IPP conv will give faster run time ?
Eran
Chao_Y_Intel
Eran,
For the Conv function, it internally may use the FFT functions depending on the image size, data type, etc.
For example, in the ippiConvFuLL,
It takes some the condition like the followings:
#define _FFTUSE 63 * 47
#define MAX_DIR_KERNEL 11 * 11
if(( dstSize.width * dstSize.height < _FFTUSE )|| ( kernel.width * kernel.height < MAX_DIR_KERNEL )){/* Direct implementation here */
} else {
FFT implementation.
For your specific size, I suggestion you run the some demo \demo\ippiDemo.exe, or some benchmark tools at
\tools\perfsys\ to check one is good.
Chao
